03- 4.2 Need Help on pulley noise
Dieter621
Dieter621
32
I can not figure out which pulley is causing the noise I am hearing on occasion. The belt is new and all the pulleys seem tight and there is no wobble. The air conditioner compressor is less that 2 years old. Does anyone have an idea to figure out which one is going bad?
3,291
188
In my own world
Check the tensioner, make sure it is as tight as it needs to be
Check idler pulely, they usually go bad, a little at a time, then lock up
Remove the belt to check these
You can also take a stethescope, and check each component while it's running
384
Good replacement for stethoscope is a cut garden hose or wooden broom handle that's broke short
Smokin' Tires with my 5.0 on Tapatalk
Dieter621
Dieter621
32
Thanks
Thanks for the input. I give this a try and see what happens.
