- 3
- 0
I have a 2001 F350 4X4 with the Triton V10 (74,931 miles) that is giving the cylinder 1 misfire code (P0301). I’ve switched the #1 coil with cylinder number 6 and the #1 plug with cylinder number 2 and it is still giving the same cylinder 1 misfire code.
It is definitely not running right and it is especially noticeable at idle, it will run rough for a few seconds then smooth for a few seconds then rough for 15 seconds then smooth for 5 seconds and so on.
When I reset the codes it seems to run fine for 30 or 40 miles and then starts running bad again but this might just be a coincidence.
So my question is what else can cause cylinder 1 to misfire other than the coil or the spark plug? Any ideas or info would be much appreciated as I need to get this thing smogged soon. Thank you.
Sven
Sven
