Having a problem with the turn signals. All four signals do not work. Flashers work. Replaced turn signal flasher unit and signals still do not work. Replaced 15 amp fuse, with no change. I am assuming problem is in the turn signal switch itself?
I bought a turn signal switch and discovered that the steering column with tilt(which I have) does not allow enough room to run the switch wiring(with connector) down through the column. The connector at the end of the switch needs to be removed. How does one remove the connector? Does this involve getting a tool to remove the pins. Can someone provide a description or picture of said pin removal tool and tell me how that works?
Thank You.
Thank You.
