Hmmmmmmmmm. Well, since i have a spare t- case, i think im gunna do this conversion. If i do, ill try to get as many pics as i can. Im gunna call JBG tomorrow and see what that kits comes with
What do ya mean custom buildin their cases?
1.96 I believe
They aren't that great for low range, but it's easy enough to double it if you really need the crawl ratio (ie your motor doesn't have any nuts)
Really Paul...seriously...geezus...you're gonna argue .04????????
Yes, I am
Yes, I am
I wanted to say it as well, for spite. Came to the party too late!
is someone up past their bedtime?
So what is that, 4 hrs.
Is it me or does this site seems to lock up occationally???
I thought i read somewhere that If you take a 205, use some twin stick kit, you can gain the ability to choose high and low with one stick and choose which axles are goin and which aint goin with the other
If you don't grind the shift rail, you won't be able to shift all the positions independently.I still dont understand why ya need to grind the rails.
On a ford np 205, the shifter closest to your leg operates the front axle. All the way forward puts the front in low range, middle is neutral, back is high range. The shifter farthest from your leg operates the rear in the same way. This allows rear wheel low or high, front wheel low or high and 4 wheel low or high.
