wareagle
War Eagle
Is it an alloy of all three? Are their any cons to using lead-free versus a lead/tin alloy?
Go lead type and no the 50/50 will not work correctly. you need 70/30 that is the preferred solder for this type of work.
Once you try this and if you think you will be using this method in the future then I would get some of the lead free and give it a try to see which you prefer. I like the lead free for vertical work where it doesn't have the tenancy run off so easy. For flat work the lead type work great. it also works good for vertical work once you catch on to it.
