F 150Cobra
"Wild HoRsE" Got Torque?
hahahah
Hey all, I posted this on here a month or so ago to let everyone know how satisfied I am with the combo Jay Allen put together for me. I called Jay with what I had in mind and he designed a combo around my needs. The stipulation for the combo was 300 horsepower with a completely untouched stock shortblock, i.e. no flycut pistons or anything else, just bolt on the heads and intake, slide in and degree the cam, chip and tune, and drive away with a huge smile. The motor made 306 horsepower and 311 ft/lbs. of torque, with more to be gained when I put in an electric fan and aluminum driveshaft.
Here's my complete combo:
Trickflow Twisted Wedge Heads (58cc, Ferrea 6000 series valves, Jay's full competition bowl blend)
TrickFlow Track Heat Intake Manifold
CI custom ground hyd roller camshaft (billet core)
Comp Cams billet timing set (9 keyway) ((modified camshaft thrust plate with countersunk bolts))
Comp Cams Pro Magnum 1.6 Roller Rockers
"Blue Printed & Limited Travel Hydraulic Roller Lifters"
BBK 70mm Throttle Body
BBK 70mm EGR Spacer
C&L 76mm MAF Sensor calibrated for 24lb injectors
24lb fuel injectors
Walbro 255 LPH fuel pump (in-tank)
GMB Hi-Flow water pump
Kirban AFPR
and supporting mods:
3:73 gears , BBK Cold air intake, BBK underdrive pulleys, 3G alternator upgrade, Maximum Motorsports full-length SFCs, Maximum Motorsports Strut Tower Brace, Steeda Rear Shock Tower brace, BBK Thermo-Tec wrapped longtubes headers, Mac Prochamber, Spintech Prostreets, MGW shifter, '04 Cobra Seats and more...
Dyno Sheet
linky no worky
Requests a login
i can make a 350 Hp engine with AFR heads and a big cam ohh yeah i forgot Carbed ofcourse
I can do that without touching the heads
"The stipulation for the combo was 300 horsepower with a completely untouched stock shortblock"
I know of a certain stock "302" that will be making about 400 horse.
Of course it will have a 32v dohc all aluminum motor, but it will be in the new mustangs and f150s
Jay Allen .. To my SBFTech Faithful.
I have decided to build a 347 and document the entire build.
I am putting BIG RED on hold so I can get RED Death back on the road.
The premise of this build is to make as much power as I am capable of and prove along the way that there are too many myths that are still allowed to propagate. This is a pump gas engine and I will drive this car every day that it is not raining or snowing. I will post pictures as I have the parts, as many specs as I dare to share, and please feel free to chime in at any time. There is no question that is dumb, there is no stupid statements, I want this thread to grow and grow.
When the engine is done I hope to dyno test it at Billy Glidden's providing that his schedule and mine can get on the same page.
Here is a list of parts. I will start right at the top.
Pro Systems Dominator Carburetor
Wilson Manifolds / BG Modified Victor Jr
TEA / Ci Prepped TFS TW 190cc Fast As Cast Heads
Competition Bowl Blend
Milled to 58cc
Comp Cams Ultra Gold 7/16 x 1.72 Roller Rockers
Ci Solid Roller Camshaft on a Billet Core
Comp Cams 838-16 Solid Roller Lifters
Comp Cams 8138 100% Adjustable Timing Kit
Probe TFS TW 1.090" F/T Pistons
10.68:1 Compression @ zero deck & 58cc chamber
Scat 5.400" x 2.123" H-Beam Rods
3.400" Steel CHP/Eagle Crankshaft
ATI Dampner
RAM Aluminum Wheel
Canton Pan
Probe Steel Main Girdle
ARP Main Studs
ARP 7/16 Head Studs
2.00" Accufab Headers with 4.00" collector
5.00" oval NASCAR Exhaust
5.00" oval Custom Mufflers
Michigan 77 Bearings through out
Lightning Air Pump (after rings seat)
Royal Purple Oil
Mexican 302 Block
Jay Allen .. These are the guesses for the Project 347.
We need your name, screen name, and 20.00 Pay Pal'ed to Ron Barck.
His Pay Pal information is: [email protected]
The closest wins all "net" Pay Pal proceeds. No proceeds will be kept by myself or SBFTech.com
If your guess is dead on, CAMSHAFT INNOVATIONS will supply you with a free camshaft valued up to 400.00.
Names and guestimates will be posted here in order.
Mark Brooks: MMB 547
Jason Winchester: 408w 565
Thomas Spalinger: 347Stroker 575
Gary Harvey: 351 Windsor snake 584
Neil Lowes: Ntv69 589
Raul Aranda: silver408coupe 591
Mark Wishka: 86t-bird 592
Joe Matthews: Liljoe07 595
Sebastian Fontana: Speedoo51 599
Brian Johnson: Knowitall 603
Brendan Jones: mxracer652 605
Mark Pastir: Quickshift 607
Michael Palazzi: Jr99svt 610
Stephen Shimek: Mystang 613
Michael Palazzi: Jr99svt 615
Richard Horvat: 302ute 618
Marcus Wood: Mwood 620
Ron Barck: BadBird 624
Greg Horton: 88foxgt 628
Joseph Karow: Oldmanjoe 631
Scott Bonomo: Onefastsvt 634
Jason Hollinger: jtmustang 642
Tony Gossett: Tony1959 646
Edward Hood: Tenpercent 648
Nate Laufer: 289nate 655
Joseph Karow: Oldmanjoe 661
Art Berthold: Grabbem88 666
Theodore Klemm: Mean88 675
John Rusinko: Rusty105 685
Robbie Brooks: Thunderhawk 687
Timothy Sparagna: Nitrotim 735
Jay Allen .. HP thread updated.
Guesses will be locked soon.
302ute .. Cool, means we must be close. Can't wait to see what this sucker makes. Even better when it goes in the car
If you knew anything about the recent history of FoMoCo you would know they under estimate and under rate all of their numbers, Mr. Texticle.
