Well, today i put a new cap and rotor in it...cut the cat off, and it still runs like crap!! Could something be wrong with the fuel system?
Did you check your timing yet?
Nope, not yet.
May i also add that after i got it back home and shut it off.. it was taking in coolant like crazy! Like it was overheating...but the gauge didn't say so...
Well, it sounded like it was gargling. Like maybe it was boiling or something??What do you mean taking in coolant?????? Like you had to add it, or like it was pouring into the blocK?
Maybe not...but this was the first time it happened.Gauge might not read right.
No, it isn't disappearing or leaking..nope Step-Dad said it was blowing black smoke.Oh boy, that's not good. That would've been good info to have.
Is any coolant leaking on the ground or just disappearing? And, do you have white to grey smoke?
check your timing black smoke is sign when the timing jumped a tooth..
start by check your timing dude
Check fuel presure and pull vacuum line off FPR to check for presence of gasoline. If there is the FPR is toast repalce it. Fuel pressure should be about 35psi at idle and 40psi wit vacuum removed from FPR.
I this a dual tank truck?
What.. you never seen a carbed car running with oversized jets? Yes high fuel pressure will make it blow black smoke, all that extra fuel gotta go somewhere.Fuel pressure should not make it run like crap and blow black smoke.
Yes but if you look at his sig, his 302 is efi. I agree excess fuel will make a carb car run like crap and blow black smoke but I don't think it would with efi. Cause the amount of fuel is controlled by injectors.
The truck will start up fine when cold, rev up when not in gear...once it goes into gear, no power.... and once it stalls, you have to put the pedal to the floor for it to start.
Still a fuel problem?
