Lowering on the Cheap
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
i removed 2 leafs from the rear and cut 2.5 coils from the front and then re adjust the chamber this is my result
F 150Cobra
3,642
104
Aruba
maximum that was available.. i think it was 4 or 6 degrees i dont remember..
for the rear u gotta remove leafs and see how it sits.. after about 4 tries i got it right i removed the shortest and before longest leaf
BE SURE TO ADD TRACTION BARS IN THE REAR BECUASE IT WILL WEEL HOP AND LOOSE 60% CAPABILITY TO HAUL HEAVY STUFF
i dont mind cause i only drag and cruise i dont use it to haul stuff
the front
i cut 2 coild if i remember right
if u want i can try and take a pic of the rear leafs
Ridgerunner
573
Stillwater Ok
the front
Yes Please picture will be helpful. But How long is one coil? And Can I use my chop saw to cut them?
F 150Cobra
3,642
104
Aruba
i didnt even remove the coil to cut it.. ( yeah i went crazy that day with the grind machine ) i did measure it about 10 times tough.. i dont know how long it is just try cutting 2 coil a way that it will sit like its in the picture so u can use a U bolt for extra safety hope u can see it in the pic
ok tomorrow i will take a pic and upload it when i get a chance
Ridgerunner
573
Stillwater Ok
Great I look forward to seeing pictures. I know you are running 2 Gen Lightning wheels, what size tires are you running. Also can you include a picture of your traction bars?
F 150Cobra
3,642
104
Aruba
im gonna take the pic now... tire sizes are 280/40R18
Ridgerunner
573
Stillwater Ok
Thanks Jurgen, Did you have to reset your pinion angle on the rear end?
I still haven't seen the spacer you have told me about a few months ago.
The thing on the bottom of the spring in Jurgen's picture with the two eyelets I think is what he is talking about.
flareside_thunder
7,812
246
It will still bolt in. There's a washer that sits inside the coil that retains it to the beam. The bolt that the washer is fastened with goes completely through the beam.
Ridgerunner
573
Stillwater Ok
This is getting a lot easier to do. What size camber spacers did you have to use? I can't remember.
