head gasket blew rest of the way
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
Use a cro bar itll give ya alot more leverage than a punch will. What I have to do on the 72 is get underneath and push that side of the exhaust up while dad puts the bolt in.
Win...that's I do most the time too.
Already done that.
Do you really need to go buy a drift...use a piece of brass, rebar, who gives a damn, all you need is the general shape and size. FWIW, that's why when space is tight, I install the head with the manifold already together, then just worm them into place.
1985 Ford F-150
7,816
307
Tooele, Utah
Use a jack with a piece of wood on it. If youre just tryin to get the hole lined up loosen the rest of em up and stick a phillips screwdriver in the top hole while ya put the bottom bolt in. If that dont work take the rest of em out and do the hard ones first.
flareside_thunder
Florida Chapter member
7,812
246
I agree, I don't have this problem anymore Chris, I've got exhaust manifold studs.
Me too. I think I even suggested that in here or another thread before or mentioned I had studs as well. Makes it so much easier.
