6.0 Tear Down
Sparky83
Virginia Chapter member
5,571
226
Norlina NC
yup that little cute one lol... ive been searching for the little steel sleeves that should have been with the others but cant find em where ever they went..
4 actually.. 5 would be to replace the one thats still there......
Sparky83
5,571
226
Norlina NC
got the turbo back in.. had to free the compressor wheel... apparently the oil started turning to gum inside from sitting... hope the vanes will free up when the actuator actuates with the pressure... will let it run awhile to warm up the oil once i get it back together.. hoping thatll do it..
Not sure I'm going to be able to help. every "sleeve" I have would be too loose for you, as mine measure out to be standard . I closed the shop in 2001, and hadn't upgraded to metric supplies.
I can send you something that will be loose on the bolt, but I don't know how you will put the rubber sleeve on it into the bracket.
Is this bracket coming from Ford with the sleves and grommets already installed?
If so, sadly, you may end up having to buy the bracket
Let me know if you want what I have
Sparky83
5,571
226
Norlina NC
it does unfortunately.. seems everyone i talk to is pointing that way ill end up having to just buy a new one unfortunately :(
Sparky83
5,571
226
Norlina NC
got it a little closer...
Sparky83
5,571
226
Norlina NC
Got good news and bad news today...
Bad news..
went to plug this sensor in and it laid over with barely any pressure..
on the up notes...
At least it broke now while you know about it, sucks though.
Did you put the blue spring in the fuel regulator?
Sparky83
5,571
226
Norlina NC
when it was still the stock one yes.. had 3 of them thats part of why im converting to regulated return...
that sensors going to be more money i didnt want to spend :( aint cheap either..
Sparky83
5,571
226
Norlina NC
exhaust back pressure sensor...
I see...I will be checking back on this thread when I remove my turbo....great writeup Shawn.
Sparky83
5,571
226
Norlina NC
if your rebuilding it i think i had posted another thread on that...
and found out that sensor runs $60-$130 depending who you get it from..
You are right, it was another thread.
Sparky83
5,571
226
Norlina NC
:) no problem man :D.. i think after i got all the seals, unison ring and new bearings.. it was about $700 ish (including the cost of the new solenoid)...
Sparky83
5,571
226
Norlina NC
i already got the new one in.. it was $60 at advance.. didnt care it was an off brand.. alliant was $130 min.
Sparky83
5,571
226
Norlina NC
got the t-stat housing drilled and tapped...
now what could i possibly be doing with these...
Sparky83
5,571
226
Norlina NC
Its getting there...
still gotta close up the hole there and put the vacuum canister back..
