Sorry man didn't give the link...
http://store.summitracing.com/partd...+4294908312+4294922533+4294839009+4294859634+
That's for an '04. I have a feeling that with the new bodystyles, Ford also changed up the damn rotors...
I will use a large ball peen hammer and using the "ball" side, hit between each stud. That expands the metal of the rotor and assists in the removal. Some have been stubborn enough that I had to use heat to remove them (and a BFH)
Warped rotors generally create a vibration in the brake pedal, not the steering wheel...
Have you checked with the local parts shops? I looked them up on Autozone's site, and they have them for 50.99, 2 yr warranty... so they shouldn't be that hard to get ahold of. Biggest headache will be getting them off.
Actually, those rotors will swap about as easy, they are still that design. But with the hub as part of the rotor, they have extra cost...
in our IFS trucks, the steering wheel vibrates hard with warped rotors for some reason. A couple years ago I (stupidly) drove through a running river on a hunting trip and got crap in my brakes, warped the s*** out of my rotors. The steering wheel would go nuts when braking and the whole truck would shake.Warped rotors generally create a vibration in the brake pedal, not the steering wheel... Though you rotors may actually be warped, it might not be enough to really cause a problem. I'd lean more towards bad alignment if you're getting a shake in the steering wheel when braking.
Line them up? How about strap them up? Anytime, anyplace. Just let me know, we'll see whos boss.IFS FTL
You should see how much the rear axle adds....what does your front suspension have anything to do with pulling power? Oh I forgot that your front axle adds 100 hp.
