5.0
FTF'er
I need some parts for a project I'm working on, so nothing is time sensitive... even if you come across some of this stuff in a few months let me know. I haven't decided for sure if I'm going 2wd or 4x4 with this project, so items 1 through 3 will be needed for sure. Items 4 through 6 I will need if I can get all of the parts reasonable.
1. the kick down rod from the carb to transmission, 460/C6 combo. A rod from anything may work, I'm using an Edelbrock carb.
2. I need one of the bolts that hold the transmission to the block, I have 1 missing. The bolt looks like the one in the pic below.
3. dipstick and tube for a 460/C6
4. shift lever and linkage for an NP205 transfer case
5. all of the bolts used to bolt the 205 to the adapter
6. 78/79 F150/Bronco radius arms, mounts for the frame, and coil buckets
