Won't Start
I have a 90 ford F150 with a 302. When I turn the key to the start position nothing happens. I have replaced the ignition switch thinking that was the problem but it was not. When I turn the key to the start position all of the normal dash lights come on and I can hear the fuel pump engage.
I have taken a screwdriver and jumped across the starter solenoid (not smart I know) and the truck will start. I just did this to try and isolate the problem.
So I know the problem is between the switch and the solenoid.
Any Ideas? I forgot to mention it is a manual transmission.
Thanks
Thanks
It maybe the starter relay...:)
Clutch switch would be a good starting place. It prevents starter function unless the clutch pedal is pressed.
