which carb. base gasket do I need?
wareagle
War Eagle
1,935
40
Hickory, NC
Autozone has 2 Felpro carburetor base gaskets for my 2bbl carb. on my 360 with what I'm assuming is the factory manifold. Their part numbers are
60094-1: Carburetor to spacer without governor
60102: Spacer to manifold without governor
Do I need both of these? If so, would 60102 be in direct contact with the manifold and 60094-1 on top of that (which doesn't sound logical so I will predict an answer of no)? Or do I just need one of the two only? If the latter, which one would I need?
I hope I gave enough information. If not, please let me know.
Thank you in advance,
Steven
If you have a spacer between the carb. and manifold then you need both. I have a spacer and needed two gaskets. The first time Autozone carried both and the second time I had to make my own for the spacer to manifold.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
C3MY-9447-A .. Gasket, Carburetor to Spacer (Motorcraft CG414) / .018-024" thick.
Fits: 1968/72 F100/350 360/390 / 1963/64 Custom/Galaxie/XL 352/390 2V / 1969/71 Galaxie/LTD 390/429 2V.
C7AZ-9447-C .. Gasket, Spacer to Intake Manifold (Motorcraft CG205) / .018-.023" thick.
Fits: 1967 F100/350 352 / 1968/72 F100/350 360/390 / 1967/71 Galaxie/LTD 390 2V / 1969/71 Galaxie/LTD 429 2V.
C7AZ-9A589-A .. Carburetor Spacer Plate.
Fits: 1967 F100/350 352 / 1968/70 F100/350 360/390 / 1967/71 Galaxie/LTD 390 2V.
All these parts are obsolete (but, can be found NOS). I listed the part numbers mainly for the applications, cuz all these parts fit more than just 1970 F100's.
wareagle
War Eagle
1,935
40
Hickory, NC
C7AZ9447C .. Gasket, Spacer to Intake Manifold (Motorcraft CG205) / .018-.023" thick.
C7AZ9A589A .. Carburetor Spacer Plate.
All these parts are obsolete. I listed the part numbers for the applications.
Thanks Bill. Prolly a dumb question, but do all carburetors come with spacers? If not, would I just need the carb to spacer or spacer to manifold?
Thanks for your help,
Steven
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
All FoMoCo OHV engines come with spacer plates...at least thru 1996. There are dozens upon dozens of different spacer plates and 100's of different gaskets.
wareagle
War Eagle
1,935
40
Hickory, NC
Thanks Bill.. Seems like I learn something new from you every day.
By the way, I got the 64-72 Ford Truck cd from HiPo. I like the fact that it is in PDF format so you can search for parts easier.
