Wheels ?
Ridgerunner
573
Stillwater Ok
Where is a good place to get steel wheels in 15x8 or 15x10 wide?
TexasNomad
FTFS Designated DRINKER!
Tire rack? junk yards Swap meets/Flee markets ..
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
What kind of steel wheels are you looking for? If you are looking for any kind of chrome mod, chrome spoke, white spoke, black spoke etc, most tire/wheel outlet store should be able to get them. If you are looking for somewhere specific, I know summitracing carries different wheels.
Cliff...take a trip down to Galloway's. They have two fields FULL of rims...some are matched, some aren't. But last time I was down there...I got a set of 15x10 Alcoa Polished aluminums for under $150. The time before that, I got a spare set of cheap chrome steelies for Thunder in 16.5x9.75 for $55 for all 4.
Ridgerunner
573
Stillwater Ok
Just a factory looking wheel but wider for small hub caps and trim rings
I might Ben but I doubt they will have what I want.
I went and got a set of chrome stocks frm the local Pick and Pull for 25bux/peice. I found them on like 3 diff 90's F-150s and a Bronc. They look good though
If you have someone you trust with the welding do what I did. Get the wheel shells from Speedway and have your stock center welded in. They have everything from 8 to 20in wide. I did this for Blue with 8's in the back so I could run my factory dog dish caps. I bought some Wheel Vintiques from Sumitt that was suppose to take my caps $175 later they don't and stupid me painted them without paying attention so I am stuck with em. Thats when I just had mine built and cost me a grand total of $55.69 live and learn
Ridgerunner
573
Stillwater Ok
Thanks for the tip. What size tires can you run?
The prices are not bad did you have to have a hole drilled out for the valve stem?
TexasNomad
REALLY!!
I wonder if they might have any of those Turbine rims i've been searching for..
To tell you the truth I don't recall if the hole was there or if Brian drilled one. I am running 8in rims with 275/60-15 have 4in backspace. I wanted the tires just inside the fender lip so they are out as far as possible but if I overload it they still tuck up in there without rubing. But if I load it that much I don't think the tires would handle it lol.
Just as a side note on Stockton wheel. Their prices are prettty salty IMO. And I have heard they are quite slow.
REALLY!!
That's one of those rim sets that you would have to piece together. I wanted a set, but normally they just have one or two lying around.
shoooot Tex I had a set I just gave away.......
WTF...even after my rim thread...where I said I wanted a set...good lookin out bro...sheesh. HAHA
