What Year is This?
The hood emblems appear to have no reflectors. By that fact alone, it's a '67.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
The guy just called me. It is a 67 with a 390 in it and 5 speed manual overdrive. He just put a new clutch in and saw the cab mounts are bad. Too bad I don't have the money to buy it.
On sale day, 352 engines magically become 390's.
No such thing as a 390 (or 360) engine factory installed in a 1967 F100/350, the only available V8 was the 352 2V.
These two engines were factory installed in 1968/76 F100/350's. 360 only with 4WD.
No such thing as a manual 5 speed overdrive until 1988, so the trans has been swapped....but how the guy managed to bolt it to an FE belllhousing, I dunno.
The hood coulda been replaced, so you cannot rely on hood side emblems to ID the year. The following info is more reliable:
1967's and 1968's before serial number C56,001: The upper side mouldings are 1 1/4" wide.
1968's from serial number C56,001, 1969's and 1970/72 Customs/Sport Customs: The upper side mouldings are 1 1/2" wide.
1967: You push the inside door handle forward to lock the doors from the inside. 1968/72's have door lock knobs, and use different inside door (and window) handles than 1967's.
