what size is the drain plug bolt from oil pan ?
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
mine thread is gone.. and its leaking.. now.. i just did a tune up yesterday im gonna drain the oil in a clean container and refill its ok to do that right?
nway whats is the size of the bolt? so when i go buy a new one what size should i ask for?
when i bought a new one for my old truck i just told them what i had at the parts store - they grabbed the right one.
i'd say draining into a clean container should be fine. just make sure its really clean. if it was me, i'd spend the money on new oil (even though i hate to), because if something happened i'd be kicking myself over trying to save $15
Lost
PA Chapter leader
3,288
central PA
I'd put clean in but u can run through filter . All the more threads shaving the new plug and old plug make will be minimal . But At least run through cloth or filter . The $15 for new is cheap compared to motor.
I have the oversized plugs on shelf . I run into this quite often .
F 150Cobra
3,642
104
Aruba
this is why i want the size.. the napa guys gave me te wrong one.. it registered in thier pc fro 1990 5.8 but its a little bigger :S... i need the priesies measurment anyone?
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Oil pan drain plug
this is why i want the size.. the napa guys gave me the wrong one..it registered in their pc for 1990 5.8 but it's a little bigger :S... i need the precise measurement anyone?
If the drain plug is stripped, better take a look-see at the threads in the oil pan...usually when one is stripped, so is the other.
Parts stores sell oversized drain plugs...there's #1 oversize, #2 oversize.
These plugs cut their own threads in the oil pan, and if a #2 won't work, the oil pan has to be changed.
1990/91 5.8L's (351W) could have two different drain plugs AS ORIGINAL. One is metric, the other one isn't and fits dang most every Ford engine from 1954 thru 1991.
If metric, the bolt head has a large M on it.
Doesn't really matter tho if the pan threads have been compromised, the oversized drain plugs are universal and will fit anything.
As original Both are available from Ford.
Metric drain plug: F75Z6730BA / No size listed in the parts catalog.
MSRP: $8.32 / FTFpartsguy.com price: $5.99
Non metric drain plug: D6TZ6730A = 1/2" -20.
MSRP: $4.28 / FTFpartsguy.com price: $3.08
NOTE: If NAPA sold you the wrong drain plug, and it's larger, and you screwed that into the oil pan...the threads prolly have been compromised.
F 150Cobra
3,642
104
Aruba
i found an normal size one and it fitted thanks
