What fluids do you use????
Hey fellas, just wondering what fluids you guys use in your dentsides...
Here's mine-
Oil: MC 10w40...or 20w50 if I have lots of oil burning
Tranny: Redline ATF
Gear lube: Lucas 80w90
T-Case: Lucas 90 weight
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
Oil: Whatever I have at hand cause it burns a ton
Trans 140w90 gear oil
T case same as trans
Diffs 80w90 limited slip stuff and a package of limited slip addative for the rear for good measure.
TexasNomad
FTFS Designated DRINKER!
RP front to back on my trucks.
all the trucks get 10w30 Ranger gets 5w30 trannys get Max ATF rear ends get 80w90..
Engine: Napa 15w40
Trans: Whatever I have on hand
Transfercase, diffs: 90 weight
UNRULEE
^LARGE carbon footprint^
5,412
424
Coal Country, ND
Engine= 15w40 Rotella in the summer and 10w30 Rotella in the winter
T-Case and axles = Run if the mill off the shelf 80w90
Trans = Whatever the guy at Napa sold me when I installed the plug in the pan
chuck101st
Springfield XD-9
2,450
201
Downs,IL.
Engine-Castrol 20-50
everything else whatever I have on hand
Texaco Havoline 30w
Motorcraft Dextron II
F-Type Motorcraft for Powr steering pump
Ford rear gear oil
Esso Brake Fluid
Prestone Anti-freeze
Glacial Zone WW fluid
Distilled water ( battery)
R/O water (My gullet)
Oil: 20W50 Castrol GTX since it was new
Tranny: Motorcraft Mercon V
Gear lube: Standard MC
T-Case: Standard MC
Sorry if I wasnt supposed to post...
masterbeavis
California Chapter member
69
4
Engine=walmart
Trans=walmart
manual trans=stinky black fish oil
radiator=rust
diffs=chocolate milk
brake fluid=yes, once I pour the water off of the top of rusty jar f used fluid...
Amsoil in everything.
Really????? That's surprising...I've never heard any good about amsoil. What makes you stick with it?
I have been using it for 20 years as have a group of us, some with 20-30k engines...never had a problem....for the last 10 years I have been getting oil analysis work done and it has never come back in a negative fashion.
