What do these numbers mean?
BUCKEYE BOB
I found these numbers on the passenger side of my engine,can anyone
tell me what they mean? C90E-6015-E3AZ & underneith those numbers
are these numbers 8K23 then there is a 79 by the last plug &
a 17 by the startersmilieFordlogo
384
the c9 is a casting number.. telling you that engine block is a 1969 casting.
what engine is it? if its 302 or 351W then ya got a good pre 74 with stronger walls cause the higher nickel content and thicker webbing.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
But, the C90E block was cast in 1968. 8K23 = October (K) 23, 1968 (8).
Casting numbers are foundry marks only, cannot be cross referenced to Ford part numbers.
302 introduced Spring 1968 for Passenger Cars. Bronco, E100/300, F100: 302 intro'd for the 1969 model year, that began September 1968.
