Weird breaking noise.
TexasNomad
FTFS Designated DRINKER!
Guy guys I was out driving around today and when I hit the breaks I hear this dull thunk sound, and its only when i'm moving at about 35+ and it shoulds like its coming from the middle of the truck..
I crawled around underneath the truck and could find any thing..
Any ideas?
U joint going bad? Did you notice any play in your driveshaft at either end? That's what I'd put my money on if it's in the middle of the truck. Does it just happen around 35mph...or up to 35mph? I don't think it's a brake related issue...although, one time I had a pad disintegrate on me and made a similar sound, but that sound came from the wheel and then I heard the dreaded brake grind.
Blue Bomber
Tennessee Chapter member
564
24
Memphis, TN
i get that all the time. i found it to be my seat mounting bolts are loose (yeah, the're still loose....IM WORKING ON IT) see if there is anything loose in the cab.
on that note, i had a friend that had a loose spare tire under his explorer. not exactly the middle, but doesn't hurt to look.
ah yes the infamous Ford Truck Thunk.
Solved on 4 x 2's by stuffing thick grease in the Driveshaft to Transmission union to absorb and remove the clunk.
Remove the driveshaft and stuff it in by hand. about hand full does it .
I use disc brake bearing grease.
Huh, I've never had a ford do it, but my moms Pukon XL does it ALL the time and its very noticeable.
"when you don't know what's wrong, just make everything right" -Jack Duncan
(he was an extra good signal maintainer, he could fix anything! and quick too)
That worked for me when my pickup finally got the death shakes. LOL :)
Only I ain't so quick. ;)
Because...
"it takes me longer when I get in a hurry :/" -Alvin
Danggit.
Stop caring what's wrong, just check everything.
It ain't that far from one corner of it to the other! :)
"you don't know what you are going to find until you look" -Alvin
Might find more than one thing wrong, one causing a thunk...
the other some little something that doesn't make a sound but
the accident investigator would've found after you were dead? ;)
"you aren't going to find it if you don't look" -cowboy buddy of mine
Alvin in AZ
