VIN Check
Detailed Vehicle Specification
VIN
1FTSW21P15EA78084
Vehicle Line
T/F7
Market Derived Code
F
Body Cab
T/BC
Ver. Series
T/BD
Drive Type
T/E
PLT CD
A1
TRS CD
T/BE
ENG CD
T/YB
Production Date
01-OCT-04
Warranty Start Date
02-DEC-04
Selling Dealer
116542
Selling Country
USA
AWS Claim Key
Trx Code
Time In Service
Labor Hours
Dealership
DIST (Miles)
Repair Date
Prefix
Base
Suffix
Doc
Details
734795
4
9.2
FAIRFIELD FORD
4882
10-MAR-05
5C3Z
7005
AA
35231201
Customer Comments
CUSTOMER STATES HOT SMEEL VEHICLE WONT MOVE
Tech Comments
VERIFIED CONCERN LOW ON FLUID ADDED FLUID CHECK FOR LEAKS FOUND LEAK AT PTO CASE.ORDERED PTO CASE. REMOVED TRANS FROM TRUCK DISASSEMBLED TRANS REVERSE THRUST PLATE STUCK IN BORE HAD TO DRIVE PLATE OUT OF CASE.DISASSEMBLED TRANS INSPECTED ALL PARTS WORKED UP COST CAP, UNDER CAP. REASSEMBLED ALL COMPONENTS INTO NEW TRANS CASE, INSTALL, SERVICE, ROAD TEST AND LK CK OK.
Details
1708200
E84
9
.7
FAIRFIELD FORD
12870
24-AUG-05
5C3Z
17683
EAA
35963501
Customer Comments
CUSTOMER STATES DRIVERS SIDE MIRROR INOP
Tech Comments
VERIFIED CONCERN MIRROR INOP GEARS STRIPED R R DR DOOR TRIM PANEL, REPLACED MIRROR ASSY, REINSTALL TRIM PANEL, TESTS OK.
Details
3291771
05B32
15
.2
FAIRFIELD FORD
16060
27-JAN-06
36608702
Customer Comments
CUSTOMER REQUESTS THAT CUSTOMER SATISFACTION PROGRAM 05 B 32 BE COMPLETED.
Tech Comments
1 INSTALLED LABEL FOR DE GAS BOTTLE AS PER FORD INSTRUCTIONS.
Details
3291770
59B01
15
.3
FAIRFIELD FORD
16060
27-JAN-06
36608704
Customer Comments
59B01 CUSTOMER ASSURANCE ROAD TEST
Tech Comments
ROAD TEST OK
Details
3291772
05E15
15
FAIRFIELD FORD
16060
27-JAN-06
36608701
Customer Comments
CUSTOMER REQUESTS THAT EMISSION RECALL 05 E 15 BE COMPLETED
Tech Comments
1 REPLACED EP SENSOR, EP CONNECTOR, AND RECALIBRATED CONTROL MODULES AS PER FORD INSTRUCTIONS.
Details
7861523
E84
30
1.9
FAIRFIELD FORD
25579
26-APR-07
4C3Z
8A616
AA
38526901
Customer Comments
CUSTOMER STATES TEMP GAUGE GOES TO HOT
Tech Comments
RETRIEVED CODES FOLLWED PINPOINT TEST AH FOUND ELECTRONIC VISCUS FAN HARNESS CUT BY COOLING FAN, FAN SHROUD AND DIP STICK TUBE DAMAGED. REPLACED FAN CLUTCH, FAN SHROUD AND DIP STICK, REASSEMBLED, SERVICE COOLING SYSTEM, ROAD TEST OK.
Details
8800705
E84
35
5.5
FAIRFIELD FORD
32068
04-OCT-07
5C3Z
3050
AB
39303002
Customer Comments
CUSTOMER STATES THE WHEEL DOES NOT RETURN TO CENTER AFTER TURNING
Tech Comments
1 REMOVED LEFT AND RIGHT SIDE DISC BRAKE CALIPERS REMOVED SPINDLES PRESSED OUT LEFT AND RIGHT SIDE BALL JOINTS ALIGNED FRONT END ROAD TEST OK.
Details
8928414
S07
35
1.2
FAIRFIELD FORD
32068
05-OCT-07
9D475
39308201
Customer Comments
CUSTOMER STATES SMOKES ON START UP
Tech Comments
RETRIEVED CODES PASS CHECK EGR VALTAGES GOOD.RUN AIR MANAGEMENT TEST ON WDS PASS REMOVED EGR VALVE, CLEAN VALVE AND BORE OF CARBON, ASSEMBLE AND RETEST OK.
Details
10729701
S07
51
4.4
FAIRFIELD FORD
54650
20-JAN-09
4C3Z
9E527
BRM
41330701
Customer Comments
CUSTOMER STATES START THEN STALLED CUSTOMER REPLACED FUEL FILTERS WILL CRANK OVER
Tech Comments
MISSES ALL THS TIME RUN TESTS CYL NUMBERS FIVE AND SEVEN BALOON TEST RT SIDE INJECTORS, ONE AND THREE INTERMITTENT. CHECK FUEL PRESSURE, FOUND TO BE LOW AT 43 PSI. REPLACED FUEL PRESSURE REGULATOR ASSY, RETEST PRESSURE, TEST OK. REPLACED RT SIDE FUEL INJECTORS, RETEST OK. REPLACED OIL SOAKED CAC TUBES.
6
thank you so much. i think im going to pass on this one :)
if I could trouble someone to check one more please, this one is an 08, also the 6.0.
im new to the world of diesels, and am very afraid of buying 'the wrong one'.
learning a lot just reading the sticky threads on the boards. thank you everyone for you assistance.
Second Truck:
1FTSW21P87EA98478
its an 07
VIN
1FTSW21P87EA98478
Vehicle Line
T/F7
Market Derived Code
F
Body Cab
T/BC
Ver. Series
T/BD
Drive Type
T/E
PLT CD
A1
TRS CD
T/BE
ENG CD
T/YB
Production Date
07-SEP-06
Warranty Start Date
02-OCT-06
Selling Dealer
116575
Selling Country
USA
AWS Claim Key
Trx Code
Time In Service
Labor Hours
Dealership
DIST (Miles)
Repair Date
Prefix
Base
Suffix
Doc
Details
4526550
E84
32
2.3
INDEPENDENCE FORD, INC.
35581
04-MAY-09
5C3Z
2140
HA
27802501
Customer Comments
CUST STATES BRAKE PEDAL FADES WHEN APPLYING BRAKE
Tech Comments
PERFORM BRAKE INSPECTION OF PADS AND CALIPERS.CHECK MASTER CYLINDER..NOTED SOME SATURATION BACK SEAL OF CYLINDER SIGN OF LEAK..FLUID LOW..REPLACE CYLINDER, ADD FLUID..BLEED SYSTEM ..ROAD TEST OK
Seb
7
Could someone please check the VIN of an 2007 E-350 6.0L Diesel / ( 4x4 Quigley ) # 1FBNE31P17DA62857
thank you
