Tune-Up
JohnnyBuck
North Carolina Chapter member
Tune-up almost complete on '88, 5.0, Unable to locate the SPOUT connector so I can set the timing, I checked the shop manual and it does not show it, Or at least I did not see it...
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
spout is a line hooked up to the coil...
Will see if i can find a pic if you need.
I believe it should be labeled? On the under hood diagram or where ever the f the diagram is..
JohnnyBuck
Thanks again for your help, As it turns out the spout connector was within 6" of the dist. I actually found it after I droped a socket and was trying to find it.
It is better to be lucky than good.
Johnny.
