1994 F-150 5.8L E4OD
Pulled some codes this morning while I was fixing a squeak in the belt tensioner pully...
The reader spit out a 452 code and a 628 code...
The manual says something about a 452 being a speed sensor bad communication problem, and the 628 refers to clutch slippage. It occasionally goes into 'shifting hard' fits, and I think #628 may be DUE to 452 sending bad voltages.
Thoughts..?
Is the only speed sensor the one located on the rear differential?
Thoughts..?
