- 46
- 1
Ok, been gone a while but i need some help and can't figure this one out.
I had some issues with my 88 f250 and it was parked for a while. Figured out that i had clogged injectors and some other small problems. Replaced a faulty injector and cleaned all that were in good condition. Replaced valve cover gaskets, upper intake gasket, degreased and painted the valve covers. Redid all wireloom and fixed any loose connectors. Removed damaged smog system and capped all hard emmision lines. Capped EGR valve and blocked it's vacuum line. Fixed any leaky vacuum lines and just plain cleaned 'er up.
Also hooked the O2 censor back up as it had not been reinstalled after the exhaust was changed.
It ran fantastic for about a week. Then all of a sudden the check engine light came back on. Read code 53 tp above voltage. Backprobed the connector side and it read that the voltage was 4.5 or stuck open. So replaced the TPS. Now it reads code 63, voltage is below minimum.
What the heck is going on? It only starts to code this way after it is up to normal operating temp. And if I shut it off when it's warm, it won't restart. If I let it cool for a few it starts back up and the code is gone.
Any clue?
Any clue?
