F 150Cobra
"Wild HoRsE" Got Torque?
im working with a ford tech so now im getting much much experience and i will post whatever i can do to help
a f150 we fixed today
came in with a bad coil pack so we fixed that and the car still kept idling rough and LOW on power i mean the Triton 5.4 i know if you floor it from a dead stop they will smoke some tires!! well this one drove like a 4 cyl
the IDS showed rough idle but very inconsistent and no codes!
so after a day of trouble shooting we checked fuel presser! and it was LOW! 15 PSI at idle!! we thought OK bad pump
turns out the pump wasn't bad it was the rubber hose in the fuel pump unit that goes from the pump to the connections has cracked and leaks soo the pump works but doesn't get the pressure up to where it suppose to be at the fuel rail.. we patched the line and wow! it now smokes the tires from a dead stop with no prob!
