time to test your knowledge
what component of the clutch splines onto the input shaft of the transmission?
A transmission has a blocking ring clearance of .035. The spec for the blocking ring is .028. Is the blocking ring clearance within specs?
(careful with this one) What do the pinion gears on the differential in a transaxle do when driving straight ahead?
82
Clutch disk hub.
A blocking ring is a part of what component in a manual transmission?
Synchronizer?
No. It is too loose.
Pinion gears will are not rotating, the carrier is spinning.
Clutch disk hub.
Synchronizer?
Very good! The blocking ring clearance question isn't fair because I didn't say "minimum" The clearance is actually OK.
1,320
82
I have no idea. Of course the spec. will have a tolerance, but as to why the reading is OK, I have no idea..
If I better knew it's function, maybe I would understand, but my guess is because it will still stop the transmission from selecting two gears. ;)
I am itching to Google it!
The measurement is taken between the blocking ring and the gear. When the ring wears, the clearance measurement gets smaller (thus .028 minimum, and .035 is ok).
