Thinking thermostat, but....
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Vince, oh guru of 6.0's, I am having an issue. Truck will only get warm inside the cab under HEAVY engine load, but then it cools back off. Electronic clutch on the fan is running ALL THE TIME, but only after the dummy water guage says warm.?!
I am going to check the lower rad hose tomorrow as I don't drive this truck much but do have to get her out tomorrow.
Yeah, If the thermostats were stuck open (or not there) It'd behave like that.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Replaced it and found the coolant low as well. When I took the t-stat out there wasn't any coolant that came out. I was surprised and it took about 2 gallons to fill her up. Any ideas as to where the coolant is going? I have no moisture coming out of the tailpipe and I am afraid to pull the dipstick LOL
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
But as far as everything else that I had an issue with it was fixed with this.
Usual places, water pump, hose under the turbo (pass side), degas cap, or if the front cover is cavitated, into the pan.
