That's right.. I've determine my goal for my truck.
I wanna be THE FASTEST naturally aspirated factory tune factory ECU speed density truck in the world.
From my research that's basically getting into the 12's 1/4 mile.
So for those of you that don't know the truck here's the spec list.
92 F150 reg cab short bed Flareside
ENGINE
5.0 W/.030 overbore
Flat Top Pistons w/valve relief
Comp 35-349-8 roller cam
Scorpion 1.72 Roller Rockers
Trick Flow Track Heat Twisted Wedge 170cc w/58cc chambers
Ported Truck intake to match heads (Trick Flow intake to come soon)
BBK twin 61mm Throttle Body
EXHAUST
Hedman Long Tube Headers
2.5" pipes
Magnaflow Cats
X-pipe
Dual spintech race series mufflers
Exit in front of passenger rear tire.
Fuel System
255LPH rear pump
Stock volume front pump
BBK Adjustable Fuel Pressure regulator
24# injectors waiting for installation in future
TRANS
AOD
Red Clutch Packs
2" OD band
Rebuilt valve body
Stock Convertor (Need 3k stall)
3.55 Gears Non-LS.
Needed items for goal
Trick Flow intake &TB
3k stall convertor
24# injector installation
4.10 gears and Locker
Suspension overhaul and lowering. Maybe go ahead and do a coil over rear suspension with major traction bars..
Drag radial Tires
ENGINE
5.0 W/.030 overbore
EXHAUST
2.5" pipes
Magnaflow Cats
X-pipe
Fuel System
255LPH rear pump
TRANS
AOD
Red Clutch Packs
2" OD band
Rebuilt valve body
3.55 Gears Non-LS.
3k stall convertor
Drag radial Tires
