- Moderator
- #1
Tech A says leaking fuel injectors may cause fuel supply pressure to drop when the engine is off................Tech B says fuel supply pressure will drop with the engine off if the fuel pressure regulator vacuum line is disconnected. Who is correct? A) tech a....... B) tech B......C) Both......D) neither
