mtflat
Flatheads Forever
- 2,559
- 147
I'm modular stupid - now I've got that out of the way, I could use help with a problem.
My daughter, 1500 miles away, has a '97 Expedition 5.4 that recently spit out a plug. She drove it carefully about 2 blocks to home. They had it towed to a repair shop and had the plug/head repaired, but another problem has shown up. (Repair as near as I can tell was heli-coil type repair - head remained on the engine)
It won't run and a compression test apparently has pressure all over the board and varies between tests on same cylinders. Timing? Cam? ??
Any suggestions? It has 220,000 miles on the clock, so I'm thinking swap in a newer engine from a wrecked '01. Is that the best way to go or can you work magic with these mod engines?
Tell me what questions to ask and I'll do my best. Thanks guys - I owe you!
