steering wheel removal
wareagle
War Eagle
1,935
40
Hickory, NC
Probably the easiest question you are gonna get, but how difficult is it to
remove the steering wheel using a puller for a 3 on the tree steering console?
Thanks in advance,
Steven
Thanks in advance,
Steven
Pretty easy, just watch what you're doing. Remove horn button, bolt on puller, screw in the center "pushing" bolt, then remove wheel.
wareagle
War Eagle
1,935
40
Hickory, NC
So, I do NOT remove the center bolt/nut you see right in the middle after removing the horn button bar thingie???
wareagle
War Eagle
1,935
40
Hickory, NC
Yeah, thats got to come out too, sorry!
Okay, just making sure... Now, I was told to be careful of the 3 on the tree shifter when removing the steering wheel??? Any idea or suggestions about that?
Basically what I'm doing is removing the wheel and feeding the turn signal switch down the steering column, then reattaching the steering wheel.
wareagle
War Eagle
1,935
40
Hickory, NC
Okay, now that I "think" I have finally corrected my charging issue with my Kawasaki VN750 I plan on attaching this Ford fix next.
Snapon, thank you for helping me out.
