Steering wheel compatability
I searched the forum and unless I overlooked it this is not mentioned. I would like to remove the aftermarket steering wheel and replace it with a used OEM / NOS one. I have found a few, but the best one has cruise control buttons. On my '79 4x4 are the steering wheels interchangeable, say for '78 and '79? I have tilt column, automatic.
The horn pad has nothing to do with the wheel as the horn pads are interchangeable
You will need a 77-79 steering wheel because of the size of wheel and the splined mounting hole
Looks Like I have lots of things you need :)
Of course someone on here will try to prevent you from buying something from me
CaFordDude
464
Cali
A users ability to offer for and actually sell an item here on FTF is directly connected to experiences other users have had with a given seller. Buyers have good experiences, they recommend a particular seller. If buyers have a bad experience they don't recommend a particular seller.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
1971/77 & 1978/79 Steering Wheels & Horn Pads
The horn pad has nothing to do with the wheel as the horn pads are interchangeable. [confused]
You will need a 77 [confused]-79 steering wheel because of the size of wheel and the splined mounting hole.
:rotz: (sigh) 1977 is not the same steering wheel as 1978/79. The horn pads are also different.
1971/77:
D4TZ-3600-A (replaced D1TZ-3600-A, B, C & D) .. Black Steering Wheel-Use without Speed Control / Obsolete/Reproduced
Applications: 1971/77 F100/350 / 1974/77 Bronco / 1975/77 Econoline.
D3TZ-13A805-A .. Black Vinyl Horn Pad with Switch-Use without Speed Control / Obsolete/Reproduced
D3TZ-13A805-B .. Wood Grained Horn Pad with Switch-Use without Speed Control / Obsolete/Reproduced
D5TZ-3600-A .. Black Steering Wheel-Use with Speed Control / Obsolete/Reproduced
Applications: 1975/77 F100/350 & Econoline.
1978/79:
E6UZ-3600-A (replaced: D8TZ-3600-A [16"], D8TZ-3600-B) .. 15" Steering Wheel-Use with Manual or Power Steering with/without Speed Control / Obsolete
Applications: 1978/86 F100/350, Bronco & Econoline.
D8TZ-13A805-B .. Wood Grained Horn Pad-Use with Speed Control-includes horn and Speed Control Switches / Obsolete
D9TZ-13A805-A .. Black Vinyl Horn Pad-includes horn switch-Use without Speed Control / Obsolete
E0TZ-13A805-D .. Wood Grained Horn Pad-Includes horn switch-Use without Speed Control / Obsolete
Horn pad applications: 1978/86: F100/350, Bronco & Econoline.
Info sources: 1964/72, 1973/79, 1980/89 Ford Truck & 1965/72, 1973/79 Ford Passenger Car (includes 1966/72, 1973/79 Bronco Parts) .. Parts Catalogs.
smilieIagree smiliewhathesaid
I have a steering wheel in decent shape sitting in my basement for a long time now. I can take pictures if interested.
How does one weed out the LIARS or those who stretch the truth on here then ?
Okay I stand corrected
I was sure it was 76 the last year for the other style
My 77 was supposed to be original and it has the same wheel and center as the 78
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
You have the same Ford parts catalogs I have. Look the puppies up...1977 is different than 1978/79.
So it looks like the ones with cruise buttons will fit any same year stock column with no issues like turn signal / shift lever? The '78 and '79 steering wheels will interchange and horn butons will swap?
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
1978/79:
Applications: 1978/86: F100/350, Bronco & Econoline.
2WD/4WD, with/without tilt wheel, what T/S switch is used, makes no difference as to what steering wheel is used.
All you need is the correct horn pad. See post #4 for the three different types.
Sounds good. I located an OEM with woodgrain and cruise buttons in pretty good shape but wondered about fit. I may add cruise later, if so I will already have the buttons for it. That will not happen though until I resolve the steering / drag issues. Thanks for the help!
With that you won't have a horn though
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
...and the T/S switch is different...Speed Control only.
