460
I run with scissors.
Hey all, I just wanted to share a few pics of the beginning of my engine swap in my '79 f150 2wd. It had a 351M/C6 in it, and I'm swapping them for a 5.0 HO and an AOD that has just under 80,000 miles.
I didn't even bother cleaning up the frame or engine because this isn't a frame off resto type project. My goal is to have a dependable truck for a daily driver that will start and idle on the coldest days, get decent fuel mileage, and cruise down the interstate with the rest of the traffic.
Here's some pics...
The old 351M just before I started to unhook everything. I am NOT going to miss this old motor... no power, tapping and knocking, low oil pressure...
Here it is hooked to my hoist just before pulling it out. This thing lifts pretty high, which worked out good since we pulled the transmission out with the engine too.
Ah, it looks much better already!
Here's my new boat anchor... :-missingt
And here's the new engine sitting in place. So far everything has gone well. The engine mounts worked with no problem, the transmission mount and crossmember each work fine, the factory AOD transmission lines (which are in excellent shape) fit perfect around the frame and motor mounts, and the engine oil pan clears the crossmember by about a foot. My drive shaft needs to be about 3" longer though. It looks like this motor was meant to be in here 8D
Here's some pics...
