- 2
- 0
I am swapping out stock engine and trans on my 48 Ford F1. I replaced with a 92 Ford 5.0 and used a C4 trans and bellhousing from mid 70s. My question is with the starter. Do I use the mid 70s starter or a 5.0 starter from the from 92? I did switch out the flex plate to a 92. I hear that the 90's era starters are designed separate for for auto or manual trans. The reason I ask is because of the 70's era bellhousing where the starter is mounted that is being used.
