special service message
1925 - 6r80 Transmission Fluid Use For 2009 Is Mercon Lv
Some 2009 Early Built F-150, Expedition, Navigator, Explorer, Explorer Sport Trac And Mountaineer Equipped With A 6r80 Transmission May Have A Transmission Fluid Indicator (dipstick) That Specifies Fluid Type 'mercon Sp'. The Correct Fluid For The 2009 6r80 Is 'mercon Lv'. The Workshop Manual And Owner Guide Specifies The Correct Fluid 'mercon Lv'. Disregard The Information Stamped On The Dipstick. This Transmission Uses 'mercon Lv' Only.
OK, now I'm confused. What if you have a pre-2009 with this transmission? Are you saying all 6r80s should use Mercon LV or just the '09s?
