460
I run with scissors.
I have 2 460 engines, one runs and the other needs rebuilt. I'm putting one in my '93 Ranger along with a built C6. Headers will be 2" primary into a 3.5" collector.
The running one is a D0VE-A block with D0VE-C heads.
The not running one is from a '69 Lincoln and has C9 heads.
I plan to use the running one as-is except for swapping an intake and cam. I'm probably going to use a Stealth intake.
1. Will this cam work well? I'd like a lopey idle if possible http://www.summitracing.com/parts/LUN-11602LK/
2. If the engine is together and running with no issues, can I unbolt the heads and bolt them back on without having them resurfaced?
The '69 engine has the crankshaft driven power steering pump. I bought the '69 engine mainly for the accessory brackets, then find out it has this antique and expensive pump on it. This engine is about as factory complete as possible.
3. If I rebuild (gaskets and o-rings) the crank driven driven power steering pump, what are the chances of it providing years of leak-free, trouble-free use?
4. If I sell the entire accessory package from the front of the motor to fund buying another package with a normal power steering pump, about how much should I expect to sell it for? (power steering pump, reservior, timing cover, alternator and brackets, A/C compressor and brackets, short style water pump, and harmonic balancer)
5. Has anyone ever used this bracket? http://www.landlproducts.com/details.aspx?cID=6&BP=0&scID=125&ItemID=1046
I'm just trying to get some decent brackets that all the belts line up perfectly with, without using washers and other spacers I find.
The '69 engine. Note the special harmonic balancer with the grooves for the belts, no crank pulley is used.
