5.0
FTF'er
1997 2.3 with a manual.
The engine idles fine, although a bit high at around 1,000 rpm, but then runs real rough after revving. The problem is much worse when the engine is cold, but still happens at all temps. After revving, it will idle rough and run rough at higher rpm's, like when I try to drive it misses out real bad. The higher it revs = the worse it will run. The engine returns to normal after a few minutes.
The only codes are P1443 and P0303.
P1443 = Evap problems
P0303 = Cylinder 3 misfire.
Where should I start?
