Replies and Views
CaFordDude
464
Cali
maybe if you make multiple posts during the same "View" session it only counts one.
Like if you make a post then see someone else made one while you were typing and you made another post before leaving the thread.
I dunno for sure though.
eco
646
12
I guess it depends what constitutes a view.
If you view the thread, make a post, hit submit then get directed back to the thread is that another view or are you still in the same view even though you have technically left (to compose a post) and came back?
I think the views mean UNIQUE views. Meaning only 1 view is possible per user per login session... Thats my take on it...
CaFordDude
464
Cali
Not 1 view per login session. If you make a post and it redirects you back to the thread it is not a new view of the thread. If you leave the thread completly, go spank the monkey (Chris) and then come back and check out the thread again that woul dbe a new view even though you are still on the same login session.
Are you sure about that?
CaFordDude
464
Cali
Guess I'll have to admit I was wrong about that. Sorry that is the way my forum software works on mine....Course mine is not as advanced as this one.
:flames: :flames: :flames:
CaFordDude
464
Cali
gimme a minute to logout and see.
Well now I AM confused...I logged completly out of the system and logged back in, viewed this thread left it and then came back and the # of views had not changed even after logging out and back in.
K so it sounds like it's unique views per IP address. Since you logged out and back in on the same IP address it didn't register. But if I viewed it at home in Davis, then on campus, and then at my moms house, that's 3 views :)
Lost
PA Chapter leader
3,288
central PA
u GUYS r rotten !! :)
CaFordDude
464
Cali
And since very few people have static IP's that could be what causes views to be so high. When I am dormant for a while and my ISP checks my status and sees that, it may every so momentarily boot me from the system and make me reconnect, thus getting a "new" IP address.
hmmm Food for thought.
TheRoadVirus
High-Steppin' Mo-Sheen
2,461
31
Ontario, Canada
I always thought it was a view per each time you viewed the thread. Meaning that if I went to another thread and came back it'd be another view.. guess not.
i'm pretty sure it doesn't count unique views
i've also seen 1 reply - 0 views
i think you can see the same thread multiple times on the same session from the same IP and have it count as a view. there could be some limit - like it won't count twice if it's within 2 minutes, or something like that
