Bob Ayers
North Carolina Chapter member
Follow these instructions, and pictures to change the instrument cluster bulbs on a Ranger (mine is a 1999, I'm not sure on what years will be the same).
It takes 6 194LL light bulbs, go ahead and change all 6 while the instrument cluster is out.
Step #1 Using a 7mm socket, remove the 2 screws holding the radio bezel
Step #2 Pull radio bezel out slightly
Step #3 Using 7mm socket, remove 4 screws holding kick-panel below steering wheel. Note: 2 screws are under hood release handle
Step #4 Drop hood release bracket and pull kick panel out
Step #5 Using 8mm socket, remove 4 of the 5 screws holding kick panel metal brace
Step #6 Just loosen 5th screw in kick panel metal brace enough to drop brace to clear bottom 2 screws in instrument cluster bezel
Step #7 Using 7mm socket, remove bottom 2 screws in instrment cluster bezel
Step #8 Using 7mm socket, remove top 3 screws in instrument cluster bezel
Step #9 With tilt steering wheel, drop to lowest position. Also pull tranny shifter to "1" position (if automatic). Note: Make sure emergency brake is set! Pull Instrument cluster out from the
top
top
