rear disc brakes
Anything is possible. Wise thing to do would be to visit a salvage yard and get the whole assembly from one with rear discs. Yes, they do make them.
nobodyspecial
Fire in the hole...
5,756
366
ND
you can use the components off of an explorer disc 8.8. They are the same, but the explorer axle is narrower. of course, the only "big" thing is that you will have to have the axles redrilled to a different bolt pattern, which is cake.
Lost
PA Chapter leader
3,288
central PA
He is building a F250 8 bolt wheels. The newer 98 up F250 trucks had disc. I believe wheel bolt pattern was same till 2002.
Swap whole rear .
nobodyspecial
Fire in the hole...
5,756
366
ND
oops, i reread it again and still read F150, i guess I am loosing my mind. :D
