rear brake stuck on Windstar
5.0
FTF'er
1,319
64
In the Middle
My Dad has a 2000 Windstar that the right rear drum brake has started sticking on. I had to use a hammer for quite a while to get the drum off and rotated the little star wheel thing in to be able to put the drum back on. As I was rotating the little wheel in, only 1 of the plungers on the wheel cylinder moved in. Now 1 plunger is all the way in and the other is still sticking out. I tried to hit it back in with a hammer, but it wouldn't move.
Is the wheel cylinder likely defective?
Yes the piston is frozen if you can not push it in.
5.0
FTF'er
1,319
64
In the Middle
Thanks, I'll have to get a new one in the morning.
I would suggest replacing both sides. While not necessarily a must I look at it as if they are of the same age and one went bad the other is probably on its way out and they are pretty inexpensive.
