Rear Axle for 59 F100
13
I need to replace to 2 rear axles on my 59 F100. It's a 28 spline. I understand they were used for many years. Does anyone know where I can find these or what part number I need to look for?
Thanks
mtflat
Flatheads Forever
2,559
147
I've found all mine at local junk/salvage yards. Pretty common where there are lots of trucks.
13
I understand it's a common problem that the axle wares at the bearing. I understand there is a repair kit for this. Just trying to find it.
Are you thinking a Speedi Sleeve?...I'm not sure if they can be used on half shafts or not.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
B7TZ-4234-A (replaced B7C-4234-A) .. 9" Axle Shaft-28 splines / Obsolete
Applications: 1957/67 F100.
13
Problem solved
I used the Redi-Sleeves, they did the job. The work on half axles, you just need to put them on with a long pipe.
