Realtime help Alternator question
You could compare the 110 amp to the one on your truck if they will let you. You would think that the 140 would be overall bigger.
Are they the original batteries?.
I would check them, I had both of mine go and it caused all kinds of issues.
look at the fusible links (3) by the glow plug module.
30
PCM only controls the alternator in the dual alternator option.
Here's the rundown.
Replaced one battery (did not have the funds for 2) the amps flickered between 14 & 13 when I was driving. But whent to 14 when idling and the battery light whent off. My thaught is a bad battery.
I'm getting anouther battery and seeing how it goes.
How can I tell if it's a 140amp alt or a 110amp. Wondering if the PO put a 110amp alt in it that's why it didn't keep up with all the accessories.
Chris
