CowboyBilly9Mile
*04 Ranger FX4 Level II, 4.0, 5R55E, 4WD (provided here since the new feature produced the result shown below)
Is there a procedure to check the blend door on these rigs to ensure that it's fully closing in the cold position? On moderate days, days when A/C isn't really needed, I seem to be getting some warm air (vent position in particular), definitely warmer than outside air, and it's not because I parked out in the sun for two hours, came back and drove away, it's like noticeable plenty of time after that (30 minutes for example). Other than that, the temp control works fine, providing a range of temps as expected. And FWIW and it's really not related to the concern, the cutoff valve in the coolant line leading to the heater core is working properly. Thanks.
<br /><br /> Year: 04<br /><br />Make: Ford<br /><br />Model: Ranger FX$Level II<br /><br />Engine: 4.0<br /><br />Transmission: Automatic<br /><br />Drive: 4WD<br /><br /><br /><br /> Transmission: Automatic<br /><br />Drive: 2WD<br /><br />
