Quick question
Quick answer, well not really...where's the pic of your truck...a styleside is like the truck in my sig. I believe fleetside is the chevy term. Flareside is the term for for the trucks that have the indented bed with the 'flare' over and around the tires. Don't forget to factor in that both stylesides and flaresides came in either the 6.5' or 8' bed.
Edit: Here's a flareside-
http://static.howstuffworks.com/gif/1970-1979-ford-trucks-47.jpg
SuperCab
547
Montana
Correct Ben.
Ford had Stylesides and Flaresides
Chevrolet had Fleetsides and Stepsides
GMC called them Wideside and Fenderside
IDK what Dodge called them...
Well i orderd one of the parts was the bedside was the fleetside 96 inches long i ordered under the ford section so im assuming its going to be the same as ford version.
So you needed to order a bedside for a styleside (like the red truck in my sig)...right? And it's a long bed right? If so, then you ordered the right dimensioned bed side. I have to ask though, which side was it for? Because on the driver's side, there were different gas tank filler door options available, so you gotta make sure you got the right onw for your truck. Also, where did you order the parts from?
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
I wonder what happened to the original tooling to make bedsides. You'd think DC would have jumped on that. That would be a nice option to have because the aftermarket stuff is hit or miss.
Jeep called theirs Townsides. I can't remember their "flareside" name, I'll look it up...
