questions about an 05 explorer 4.6
loudandlifted
bleeds oval blue
198
camdenton mo
does anyone know the way to change the combination to keyless entry on the drivers door?
is it worth putting a cold air intake on it? or just an aftermarket filter?
anyone done any kind of exhaust mods? i would like to put something on it with a little rumble but not too loud. its the wifes truck
what is the RSC transmission? benefits? weak points?
Enter the permanent factory remote keyless entry (RKE) keypad code.
Press the 1/2 button within 5 seconds to activate the programming mode. Holding the 1/2 button for more than 2 seconds after activation will erase the stored customer code. The existing code will not need to be erased to program a new code.
Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks will lock and unlock to confirm the new code is programmed. Now, remember, the original code will still work, until you replace the vehicle security module.
Those are a waste of time, in my opinion.
Just some different mufflers will do.
RSC....Roll stability control......its more ABS and electronic steering based. Theres no difference in the trans.
loudandlifted
bleeds oval blue
198
camdenton mo
thanks vince what if we dont know the factory code?
