Question for electricians.
nobodyspecial
Fire in the hole...
5,756
366
ND
GFCI outlets have two hook ups on them, load and line.
I have just put a tub in and tiled the bathroom, put a new vanity in and am going to put a wall mount light fixture above the new mirror and vanity.
I have an existing GFCI outlet in the bathroom. Would it work to power the new light and switch off of the GFCI, or would the spark that sometimes comes from a light switch trip the GFCI?
Just curious if that would work.
I have the light and fan in my master bath wired just like your asking.
I did it this way for the simple reason that sometimes I turn them on while standing in the shower. :shocked:
Which your not supposed to do.'smiliedoh'
So, if you don't login for a couple days, call 911? :D
Both our light and fan are hooked up this way and is real close to the shower.....Our bathroom is brand newly renovated and was only done this way because of space.
At one time the code read the switches were to be out of reach, but I don't know if its still the same.
My master bath was a half bath. I added the shower next to the switches.
Also used plastic screws in the cover plate.
The spark will cause no issues, but putting a fan on a GFCI can cause nuisance tripping...we will not do.
If they are within reach of the tub/shower, then they have to be on a GFI with plastic plate screws, as Mark noted.....remember that a typical hair dryer draws 1500+ watts and adding to a circuit such as the bathroom plugs can be an issue...when we wire new homes, a separate circuit is pulled for the bathroom plugs.
Code for a receptacle is no closer than 18'' to a tub/shower...and a GFI obviously.
nobodyspecial
Fire in the hole...
5,756
366
ND
Great! Thanks everyone! This will make wiring the new fixture in a piece of cake!
