CowboyBilly9Mile
Duncan, this should be right up you alley.........
I'm doing some planning on an upcoming EATC mod and the system I'm using is from an Expedition/Navigator. These use a PWM unit for the blower and it, along with the blower motor, is located inside the cabin, on the passenger side on the right and above their right foot and next to the cowl. On the PWM unit are three for four cooling fins and they make up one side one side of the unit. No fan forced cooling, just convection.
I'm running into available space problems if I try to use this same location but I do believe this can be resolved by mounting the unit inside the dash behind the center panel. There's space for air movement in there, it's not stuffed with electronics. So now comes concern #1, heat. Currently my blower circuit is 40A on #10 wire and I expect the PWM unit will use the same, plus more wire (
on more #10 wire, that's on the table for now). So, do these PWM units generate a whole lot of heat?
*I could run a bench test, but I just don't happen to have a suitable power supply to do so.
EDIT: If needed, I can take a pic and post.
