- 3
- 0
2008 F-250 XL/5.4
Truck has consistently weak air flow out of all interior vents. Mode and blend doors appear to be functioning properly. Defrost vents seem to be more restricted than others flowing almost no air at all. Recirculating improves air flow some but not much. I used a long blow gun and a vacuum attachment to clean out the HVAC inlet in the cowl (which did have some pine needles and such built up on it) and found no noticeable difference in flow. I am assuming the inlet and possibly the heater core and evap. core are simply plugged up with dirt and that I will be removing the dash to deal with this. Just want to make sure I'm not overlooking something before I do.
This vehicle is used for Wildland Firefighting and sees a lot of dust/dirt and a lot of A/C use.
No noticeable difference in flow whether at max heat or max a/c.
Truck has been acting this way since around the 25,000 mile mark.
Thanks in advance.
Thanks in advance.
