Poll. Iron vs Aluminum Block
Which block is best for building up a engine?
  • Aluminum
    Votes: 13 40.6%
  • Iron
    Votes: 19 59.4%
  • Total voters
    32
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
Well iron would be STRONGER, but it depends on what you plan on doing with the motor...
Any kind of nitrous or forced induction?
If not, go aluminum...
If so, Iron all the way...
TexasNomad
FTFS Designated DRINKER!
I'm going to say Iron.. :D
My vote was iron. I'll take strength over light weight anyday. While weight is an issue for speed...is this engine really going in something that'll be going down the 1/4 mile all the time? If not, I'll take the reliability and extra couple of pounds.
klatt_89
Gotta Be Somebody
1,889
74
Lindsborg, KS
I guess after doing some research and seeing what a few of the guys that have raced the 4.6's have said, it's either the Teksid block because it's not actually a Ford machining but their machining. Although they also said the iron blocks are pretty strong as well. A little specs of weight off of Ford Racing Performance.
Production Cast Iron 4.6 Iron Block: 178 lbs.
Aluminum 4.6 Block: 129 lbs.
Aluminum 4.6 Block for Supercharging: 165lbs.
That's just the blocks, but not a lot of weight difference really. Specs taken from:
http://www.fordracingparts.com/parts/category.asp?catID=38&catdesc=Engine Blocks
But i'd still like to see what everyone here thinks, cause i respect everyones advice.
blackhat620
You Had to be There
1,687
150
Arizona
Iron, no contest.
TexasNomad
I don't know of any body making Modular aftermarket Iron blocks.
The only ones I have seen have all been Aluminum racing block.....
blackhat620
You Had to be There
1,687
150
Arizona
Also if I've read my info correctly, Ford is going to make the 5.4 in the Shelby out of aluminum in 2011...right now it is just the heads.
